How to interface PC keyboard to uC...
t06afre
Joined May 11, 2009
5,934
First RRitesh, I know you have been on this site http://www.computer-engineering.org/ps2protocol/ Here we can read that PS/2 use a synchronous serial protocol Did you absorb ANY of that!! So then using asynchronous aproach. Do you not think that is most likely to fail. If you have no idea of what you do, then you will not be able to create anything either. Spending a lot of time using Google and then posting any code you think may work. And then asking for help will not either work. For crying out loud. Can you not just for once. Gather information, then based on that information. DO SOME CODING ON YOUR OWN. Even how painful you must think it is to actually read the datasheet, and then convert that information into code. Start simple by just setting up the PIC to use synchronous serial protocol. Then read any data from the latter port, convert it a alphanumeric hex string. And then send it to LCD
http://www.youtube.com/watch?v=ICr3ygRsJvE
RRITESH KAKKAR
Joined Jun 29, 2010
2,829
Hi again,
Here it is:
1 start bit. This is always 0.
8 data bits, least significant bit first.
1 parity bit (odd parity).
1 stop bit. This is always 1.
this is to be written in code but the problem is how to clock or data should be capture because clk is generated in device at unknown timing i don't know it perfect..
and how to make logic for parity test?
Hi again,
Here it is:
Is this how you think a PS/2 keyboard communicates?
RRITESH KAKKAR
Joined Jun 29, 2010
2,829
yes only from device to uC....and clk is generated from device only!
so, while coding clk should be input or output because we have to low or high the clk line.
t06afre
Joined May 11, 2009
5,934
Have you read this section of the datasheet? 10.0 ADDRESSABLE UNIVERSAL SYNCHRONOUS ASYNCHRONOUS RECEIVER TRANSMITTER (USART)
What does section 10.4 say? Have you tried to convey this information into some working code?
RRITESH KAKKAR
Joined Jun 29, 2010
2,829
I have this code for USART 9600 baund rate slave mode.....not sure of baud rate of PS2..
Rich (BB code):
 #include <htc.h>
__CONFIG(LVP_OFF & BOREN_OFF & PWRTE_ON & WDTE_OFF & FOSC_HS);
#define _XTAL_FREQ 20000000
void  HSerinit(void),Hserout(unsigned char ch);
unsigned char HSerin(void)  ;
void main(void)
 TRISC = 0b10000000;
 ADCON1=0X6;
    HSerinit();
__delay_ms(200);
while(1)
HSerin();
if(RCREG=='b');
RC4 =1;
__delay_ms(250);
void HSerinit(void)
    TRISC = 0b10000000;                   // TX was an input!
    SPBRG = 51;                    // 20Mhz xtal 9600 BAUD
    TXSTA = 0b00110000;  //Synchronous mode Slave mode
    RCSTA = 0b10010000;//Serial port enabled Enables continuous receive
 {     while(!RCIF);                    // Wait for a character
 return RCREG;                    // return character
PS/2 doesn't have a baud rate, it's synchronous clock & data. But you're not listening so let me tell you about what a nice day outside it is. I'm going to pickup my awesome Pedego Interceptor bicycle from the shop after getting its wheels trued. Did I mention it's red! Isn't that exciting!. Wheeeee.
35,117
NRZI, UART, ACIA, SCI, USART, RS-232, COMM PORT, are all one of many ways to do serial communications. To learn about PS/2 read the PS/2 serial specifications.
tshuck
Joined Oct 18, 2012
3,534
Yes, i have seen many link but need help in programming code how to capture the data with device clock?
Start at the beginning. Learn how to program, learn how to use a microcontroller, read the relevant information, then, using your understanding from the previous three experiences, write a program that will accomplish what you want instead of asking others to do it for you.
RRITESH KAKKAR
Joined Jun 29, 2010
2,829
OK, i am doing one thing ....i have connected switch across data and clock for testing code but terminal window is not showing the data iam feeding from switch is there and problem with code?
Rich (BB code):
 #include <htc.h>
#define CLOCK RC1
//#define DATA  RC0
void  HSerinit(void),Hserout(unsigned char Data);
unsigned char Scan_Data(void);
unsigned char ch;
void main()
   //PORTC=0xFF;     //Pull up the inputs to High
  TRISC4=0;
TRISC0=1;
TRISC1=1;
 HSerinit();
  __delay_ms(100);
ch='a';
Hserout(ch);
      while(1)
     // ch=Scan_Data();    //Scan for a incoming data
RC4=0;
RC4=1;
__delay_ms(200);
    unsigned char Data=0,temp;
    if(CLOCK==0);   //Wait for First Falling Edge
   // CLOCK=0;     //Clear the Flag--Bcoz this is Start Pulse
RC4=0;
RC4=1;
__delay_ms(200);
    for(char i=0;i<7;i++)
RC4=0;
RC4=1;
__delay_ms(200);
        while(CLOCK==0); //Capture the next 7 bits of data
       //CLOCK=0;
        temp=RC0; //DATA using switch
        temp<<=i;
        Data|=temp;
 RC4=0;
RC4=1;
__delay_ms(400);
    ch=Data;
Hserout(ch);
RC4=0;
RC4=1;
__delay_ms(200);
    ch,Data,temp=0;
RC4=0;
RC4=1;
__delay_ms(200);
void HSerinit(void)
    TRISC5 = 0;
                  // TX was an input!
    SPBRG = 129;                    // 20Mhz xtal 9600 BAUD
    TXSTA = 0x24;                    // TXEN and BRGH
    RCSTA = 0x90;                    // SPEN and CREN
void Hserout(unsigned char Data)
    while(!TXIF);
    TXREG = Data;
RRITESH KAKKAR
Joined Jun 29, 2010
2,829
My code suck here after while..i was testing the clock and data is input with pull ups of 4.7k using switch to gnd.
so, net voltage on uC pin is 2V but it should be 5V...and i don't understand why RC4 is not going high after while statement i have connected switch with gnd pressing it is also not doing any thing ,why?
Rich (BB code):
void main()
TRISC4=0;
TRISC0=1;
TRISC1=1;
 HSerinit();
  __delay_ms(150);
ch='a';
Hserout(ch);
      while(1)
RC4=0;
RC4=1;
__delay_ms(200);
RC4=0;
   while(RC1==0);  {   RC4=1;
__delay_ms(400);
RC4=0;
__delay_ms(400);
