- Joined Jan 23, 2018
- 28,231
OK, that aside was relative to the comment about a car on a small battery.
To indicate at what sort of distance from the valve being operated?? A small flagon a pivot with two solenoids to move it, and diodes in series with each so that only one can be powered from each polarity.
OR, if the water flowing out of the valve is at any pressure head, even a few PSI, a vertical (water) hydraulic cylinder to raise a flag to show discharge pressure. It would take a very low friction cylinder, or maybe a diaphram cylinder, not a standard one.
