Please how do I make the current of this cct to vary between 2-15A. I want to be using the charger for both lead acid and deep cycle batteries.
This is really helpful, thanksBesides the mains transformer being uprated for the required current, transistor Q1 will need to be mounted on a heat sink capable of handling the power dissipation*.
Diodes D4, D5 & D6 will need to be uprated to handle the maximum charge current and the value of resistor R5 will need to be reduced such that at the maximum charge current 0.68V appears across it (to switch on transistor Q5).
You will probably need to increase the capacitance values of C1 & C2 by a factor of at least 10.
* with a flat battery and maximum change current it is unlikely that any size heat sink will be adequate for the power dissipation – so you will need some other arrangement (probably involving an additional 2N3055 transistor to share the power dissipation).
