How to have capacitor power only one part of parallel circuit?
33,374
I am in awe! Being a beginner, I never saw such complex circuit diagrams before.
Thank you for the time and effort you spent putting them together. I appreciate that. Like I said earlier, I don't want to take too much of your time, because I don't know if I want to implement this for my hovercraft right now.
I think there are several potential issues with this circuit (please correct me if I'm wrong on any of them):
  1. It would be difficult to fit all of the components underneath the foam plate, which is about 6in in diameter and ½in deep and has a 2in-diameter hole in the middle for the fan to blow through.
  2. There is a lot of variability of the duration in which the LED should/would fade out. This would be affected by: (a) strength of 9V battery, (b) strength of coin cells, (c) transistor gain, which you said can vary by a factor of three or four.
  3. Sorry, but it's far more complicated than what I would want for a small hobby project.
All of the components, including the coin cells, will take up very little area. If you wanted to use surface mount components all of the components, excluding the coin cells, would take up the space of something like a quarter. With through-hole components they should still pretty easily fit in a space that is less than, say, 1.5" on a side.
The circuits that use multiple transistors will have very little dependence on the transistor gain. There will be some variation due to the strengths of the batteries, but I doubt it would be that bothersome. The same is going to be true for you original (patched) approach. The time can be made more regular by adding some regulation via zener diodes, and actual voltage regulator (which is the same size as the transistors), or using a 555 timer.
As for the complexity, that is definitely something that you have to decide for yourself.
tjohnson
Joined Dec 23, 2014
611
the cap value could be reduced down below 1000 uF if a transistor is added to the circuit
No battery, no power.
So just to make sure: there is no place at all in the circuit where I could add a transistor to reduce the value of the capacitor and have the desired behavior? Including the branch of the parallel circuit where the capacitor is?
ronv
Joined Nov 12, 2008
3,770
Think of the capacitor as a little battery. It gets charged up buy the big battery and discharged by the LED. The time it lasts is determined by the LED current.
You can make it work with a regular battery and a transistor (to make it fade) because the regular battery holds more power.
It could be done fairly easy if you could use a red LED and a very small coin cell battery along with a transistor.
Tell us why you want it to fade out rather than go out when you disconnect the battery. Maybe that will spawn some ideas.
tjohnson
Joined Dec 23, 2014
611
Thanks. WBahn also designed a circuit showing how I could use transistors to make the LED fade.
Originally, I was thinking:
When the hovercraft is turned off, it takes a while for the fan blade to stop rotating (naturally, without a capacitor), and I thought it would be neat to have the LED fade out simultaneously. (I mean that the LED wouldn't completely go out until around the time when the fan blade completely stops.)
but later on I said:
I really want the way the LED fades out to be consistent, and after thinking more about it, I think having it fade out in 4.8 seconds along with the fan is too long a period of time. I think a diode and 1000μF capacitor (which after measuring again, I believe will just barely fit) is probably the easiest way to achieve something close to what I want. I know the fading out of the LED will last for less than a second, but it's definitely noticeable. (I can even notice the 100μF capacitor very slightly when I have it wired correctly, and of course the 470μF one even more).
Right now, I'm leaning towards using a capacitor, but still possibly open to using a transistor.
tjohnson
Joined Dec 23, 2014
611
What value resistor are you using now?
470Ω
I'm not using the LED as an indicator light, but as decorative illumination for the hovercraft, so I want it to be as bright as possible. It was barely visible when I tested it with a 470k resistor, so it would probably be visible with a 4.7k one, but I really don't want to use a larger resistor with it than necessary. So I think I want to use a larger capacitor instead.
ronv
Joined Nov 12, 2008
3,770
You might try about 750 ohms and see what you think. That would stay on longer and be nearly as bright.
tjohnson
Joined Dec 23, 2014
611
Thanks for the suggestion. I'll have to try it. I'm planning to get a diode and probably a bigger capacitor this afternoon, and will report back on how they work.
tjohnson
Joined Dec 23, 2014
611
Place a diode in the top line between the fan and the capacitor.
Thanks, that worked! I used a 1N914/4148 diode and switched to a 1000μF capacitor. (Oddly, I found that a 1000μF capacitor from an assorted pack at RadioShack is less than half the size of a 470μF one bought individually.) The LED actually does fade out now in about the time it takes for the fan to wind down, so I'm happy with it and I think my project is completed.
Thank you to everyone for their helpful and informational posts!
tjohnson
Joined Dec 23, 2014
611
Could you post a final schematic?
Sure, here it is:
I tried that on a breadboard, but didn't need to do it for the hovercraft since the LED fades out in about the time I wanted it to using just 470 ohms.
Also, since my last post I figured out that the reason why the assorted capacitors I got are smaller than the ones I bought individually is because they have a smaller maximum voltage.
EDIT: Replaced MS Paint drawing with circuit diagram made in TinyCAD. Updated diagram on 1/24.
tjohnson
Joined Dec 23, 2014
611
I started using TinyCAD this past week, so I replaced the MS Paint drawing above with a better circuit diagram.
