How to get trigger pulse when a relay is Energised and De Energised
kosss
Joined Jun 29, 2015
7
Hi
I have a 12 volt relay being activated by a timing circuit (so 12 volts is on the relay while it counts down the prescribed time)
I need a trigger pulse or switch pulse when the relay is energised and one when the relay is De energised
Thanks Shane
kosss
Joined Jun 29, 2015
7
Hi
just need 12v trigger to activate a 2.5v-12v input
The input (IN) requires just a few milliamps at anywhere between 2.5v and 12v.
Thanks
Reloadron
Joined Jan 15, 2015
7,904
Since you do not mention any timing periods this will be generic. I would think about using a pair of One Shot multivibrators. Something along the lines of a 74123 simply because it is dual and allows for + or - triggering. Again, you do not mention the pulse width once triggered?
Ron
kosss
Joined Jun 29, 2015
7
Hi
the trigger has to run a relay pcb with the following specs (The input (IN) requires just a few milliamps at anywhere between 2.5v and 12v)
Reloadron
Joined Jan 15, 2015
7,904
You want a pulse when a relay coil is energized and you want a pulse when the coil is de energized. Call these pulses triggers or whatever you want but they need a pulse width or duration? So when 12 V is applied to the coil you want that positive transition to create a pulse and when the 12 V is removed you want to create a pulse on that negative going transitional edge. Use a pair of one-shot multivibtators. The 2.5 to 12 V isn't the issue. Additionally DC coil relays usually have a diode across the coil to snub the inductive kick when the coil field collapses, that may need some consideration. Commonly called a "flyback" diode.
Ron
MikeML
5,444
You want to use the relay contacts to generate the pulses, or do you want to use the voltage across the relay's coil?
MikeML
5,444
Hi
I was going to try and use the relay contacts
Do you have form C (NO,NC) contacts?
So you need two outputs; 1 positive going when the relay closes, the other a positive going pulse when the relay releases?
