How to get supply output down to zero volts
blah2222
Joined May 3, 2010
582
Like thousands before me I am moving from the life of batteries and wall-warts and onto the excitement of building my own variable bench supply. I am interested in the design process so I figured I could give this a try.
It seems as though the LM317 seems to be a common choice, but I have some discrete transistors and zeners lying around and would like to make use of them.
It seems as though discrete designs using only diodes and transistors (sometimes op-amps) are fairly complex and take up a fair amount of space on a schematic.
Might this be because the circuitry to get the output down to zero volts is that much more complex and also relies on temperature regulation as well, increasing the parts count?
JP
alfacliff
Joined Dec 13, 2013
2,458
if you posted a circuit diagram, we could tell you where to put in some diodes to offset the output to zero. basicly, you offset the ground point of the supply to make the output go all the way to zero, since the regulator will not go down that far.
MikeML
5,444
Use an opamp powered with split-supplies in the voltage feedback loop to drive the Ref Pin of the regulator chip to -1.25V.
Read the app notes supplied with the various regulators at TI's web site...
eetech00
Joined Jun 8, 2013
4,751
JP
Hi
What is output voltage range desired?
What is maximum load current desired?
eT
blah2222
Joined May 3, 2010
582
For my purposes a 0-25V supply would work well. At some point I'd like to figure out a current limit circuit but I don't really need more than 0.5 - 1A.
What are thoughts on the attached circuit. The potentiometer R6 connected to the negative feedback of the op-amp through R5 allows Vout to go down to zero. Would need to get a centre-tapped transformer to get the negative rail for the op-amp. Or just a rail-to-rail op-amp. Some kind of output transistor for load current would need to be setup as well.
V_{out}(x) = 5[1+R_{1}(\frac{1}{R_{4}} + \frac{(1-2x)}{R_{5}+x(1-x)R_{6}})]
If R6 << R5
V_{out}(x) ~= 5[1+R_{1}(\frac{1}{R_{4}} + \frac{(1-2x)}{R_{5}})]
V_{out}(x=0) = 5[1+R_{1}(\frac{1}{R_{4}}+\frac{1}{R_{5}})]
V_{out}(x=1) = 5[1+R_{1}(\frac{1}{R_{4}}-\frac{1}{R_{5}})]
Where 'x' is the turn ratio of the potentiometer R6.
blah2222
Joined May 3, 2010
582
Something like this? This technique seems feasible but I feel like fluctuations in the rails would causes the diode drops to change quite a bit, giving a poor reference.
I understand that pulling the ADJ pin to -1.25 would work with a precision -1.25V regulator, but I am looking into feedback-driven regulation down to zero if that makes sense.
Hi
+/- 15V
<1A
eT
In series the bjt to the output and in parallel the pot with the bjt, and then you can adjust the current.
Is there a reference diagram you can post that goes along with your post?
#12
Look at the VI curves for the 1N4001 series. In the 10 ma range, it takes a 5 to 1 current difference to produce a tenth of a volt of change. Are your rails going to change from 30 volts to 150 volts?
PS, look at the LM723 chip for some good design ideas.
Lestraveled
Joined May 19, 2014
1,946
......what??.......no......That don't work.....
Q3/Q4, Q1/Q2 form constant current sources.........Sure they will absorb some voltage but how does this make an adjustable power supply that will regulate to zero???
ScottWang
Joined Aug 23, 2012
7,509
Yes, it won't work, because this wasn't designed for zero Vout.
I just want to suggest the current control, if he want to adjust the Vout to zero, it needs some other works.
ScottWang
Joined Aug 23, 2012
7,509
The following two circuits will be output less then zero voltage.
THE_RB
Joined Feb 11, 2008
5,438
A simple LM317 circuit will do 1.25 to 25v no problem, and there is very little need to every go below 1.25v. Even when powering battery devices with your bench supply nothing uses LESS voltage than a 1.5v cell!
Your need to go to 0v causes a lot of issues and you simply may never need that ability.
Regarding LM317 and current limiting, I have had good success putting another LM317 as a current limiter BEFORE the voltage regulator LM317. That way you get independent control of current limit and the regulated voltage. Regulated voltage remains exact until the current limit is reached.
38,946
Below is the simulation of a discrete power supply using a single-supply op amp with the pot going from 0 to 100% and RLoad stepped from 15Ω to 30Ω in 5Ω steps. It goes to from 0V to 25V output from a 30V rectified supply and is current limited to a little over an amp. Q1 needs to be on a healthy heat-sink of course.
But I agree with RB that an LM317 based power supply should meet most general bench power supply requirements, is more bullet proof, and is much simpler to implement.
blah2222
Joined May 3, 2010
582
Could the same current limit approach you used with R7/Q3 be used to proceed and bypass an LM317, i.e. PNP collector attached (through a resistor) to Vout with emitter attached to unregulated supply and base attached to input of LM317 with R7 between base and emitter?
Also, would there be any benefit to making the regulator with differential discrete transistors vs. an op-amp?
Thank you
38,946
It could work but you can't "bypass" the LM317, you need to limit the current at its input. For that you'd have to add another transistor in series with the input, preferably a P-MOSFET (or use another LM317 as RB suggested). Also note the LM317 is inherently current-limited at its maximum current rating.
None that I know of.
MikeML
5,444
I dont care much for the circuits posted here. Here is my version. Simulated only, not actually built, but I have high confidence in this LTSpice simulation.
The way I offset the Adj terminal of the LM317 to -1.25V is by using a TL431 shunt regulator, which intrinsically creates a stable -2.495V. The current that flows in R1, R2(the adjustment Pot) and R3 is essentially constant, so to effectively subtract half the -2.495V reference voltage, I just added R3, which must be the same value as R1 because the internal reference inside the '317 is 1.25V.
With R1=R3=205Ω, a 5K Pot adjusts the output voltage from 0V to 30V.
The simulation includes a transformer, rectifiers, capacitors. Note that with a Center Tapped Transformer, the required unregulated negative voltage for the TL431 reference is developed.
In the first simulation plot, I show the output voltages vs time as a function of the pot value. Note that with the transformer shown, the unregulated + voltage is ~34V with ripple. With the Pot set to 5K, the output voltage is ~31V, which is right at the point where the LM317 drops out of regulation, as evidenced by the ripple on the output...
There is also a start-up glitch (when AC is first turned on) which is not trivial to get rid of. It is caused by a difference in time when the Unreg+ first appears vs when Unreg- appears.
The second plot shows the dissipation in the LM317 as a function of driving a 25Ω load resistor and as a function of the output voltage, Obviously it would be much worse to ask the power supply to deliver a few mV at 1A where the dissipation in the 317 increases to ~35W.
