how to get 8/9 freq divider?
Hayder
Joined Mar 6, 2016
32
Hello
I build freq divider 8/12 using d flip flop, but I wonder how to make it 8/9 ?
I build my divider like:
%2/3 --> %2 ----> %2
the result is 8/12, now how can I play with gates to obtain 8/9 instead?
thanks a lot
dl324
Joined Mar 30, 2015
18,425
Take a look at the 7497 binary rate multiplier datasheet for some ideas. It won't do exactly what you want, but you can use the circuit as a starting point.
If you don't restrict the solution space to some gates, a PLL would do it easily.
dl324
Joined Mar 30, 2015
18,425
Hello
thanks a lot
Could you clarify what you mean by 8/9? I interpreted it to mean that for every 9 input clock pulses, you wanted 8 out.
Also, could you post a schematic for the circuit you referred to?
EM Fields
Joined Jun 8, 2016
578
Hello
thanks a lot
If you've built it then you must have a schematic on hand which you could post to clear up what you mean.
For example, When you say you want an 8/9 divider, does that mean that if you put 90Hz into it you'd like to get 80Hz out?\
And what about output duty cycle and input frequency?
ian field
Joined Oct 27, 2012
6,536
Hello
thanks a lot
8 isn't hard at all - there are old logic family databook on archive.org - there are probably application examples how to hook up standard divider stages for weird and wonderful ratios.
djsfantasi
Joined Apr 11, 2010
9,237
I deleted my original post. It didnt make sense (I must have been drinking). My updated response is below.
First, is the frequency you are "multiplying" by 8/9 a digital or analog signal?
If digital, read on...
Ok , but I need the circuit configuration...
Thanks
Start by multiplying your clock by 8. Or, in actuality by 2. There is a common circuit using digital logic to multiply by 2. Just apply this circuit three times to multiply by 8 (2^3=8).
Then feed the multiplied signal into a CD4017. Take output 9 and connect it to reset. Take any other output as your divide by 9 output.
This results in an 8/9 signal.
Hayder
Joined Mar 6, 2016
32
Interested...
I want to build 8/9 using d flip flops and I found this diagram somewhere
- what is the idea of putting these gates? just to understand to build more configurations like 15/16 or 31/32
- where I can put the output of 3-nor gate? without using Reset
Thanks
djsfantasi
Joined Apr 11, 2010
9,237
Where is the output of your circuit? And what do each of the two traces represent?
I have trouble understanding your circuit. U1 and U2 have their clocks tied together and to nothing else. That means to me they will never change state. And you cannot predict what that state is.
I am away from any computer (on phone) otherwise I'd simulate the circuit.​
Hayder
Joined Mar 6, 2016
32
I'm sorry for fussy circuit.
U1, U2 is represent 2/3 divider , so I connect more 2 FF ( U5 and U6) to got divided by 4 , so whole circuit is represented 8/9 divider , this is what I understand from this diagram
But the output is wrong ( the output is from U6)
djsfantasi
Joined Apr 11, 2010
9,237
I found your diagram. Unfortunately, it is only a block diagram with no further explanation. Perhaps another member can explain it.
My questions remain unanswered, so at this time I can't help further. I like the idea of the diagram because it appears simpler than the brute force approach I have in mind (multiply by 2 three times, divide by 3 twice).
