How to get 12-0-12 with two 12v transformers
Stevencage77
Joined Aug 16, 2018
Hi, everyone, I have two 200w 12v ac lighting transformers, I would like to use those as power of amp board I'm building, but the amp board requires 12-0-12ac, the lighting transformer is 12-0 ac, and it's sealed, I can't make any mod on it. So I wondering if I can use two of it to make 12-0-12v ac? Thanks a lot for answering.
ebp
Joined Feb 8, 2018
2,332
Lighting "transformers" are often not "normal" iron-core transformers but switch mode power supplies of various types which may or may not be compatible with what you want to do. A photo or two would be helpful.
Dodgydave
Joined Jun 22, 2012
11,395
Yes you can use two transformers as long as they are both the same Va rating, just wire the secondaries in series in the correct polarity, and use the junction as the CT.
T Power Electronics 39
J Power Electronics 5
