How to fix voltage drops at 220V in this inverter Circuit
naytr
Joined Feb 24, 2018
How can i fix the voltage at 220V , when I connect the voltmetre with no load it shows 220V but when I add a lamp it drops to 87V
What can I do to improve the circuit and what are your opinions about it
Help please !
Audioguru
Joined Dec 20, 2007
11,248
When the transformer has no load then it shows 220V output but on a real circuit it would be about 203V because the transformer is designed to produce its rated output voltage at its full load current therefore its resistive windings ratio (220V to 13V) shows that.
When the 220V output of the transformer is overloaded with a 12V light bulb or two of them then of course the output voltage is low but the simulation does not show the overloaded Mosfets and/or battery blowing up.
On the other website you showed that your 12V battery drops to less than 5V when the transformer has a load. Is that fixed?
Important details that you do not show is the current rating of the transformer, its output voltage with no load and the load resistance.
The transformer should be 220V to 10V or 11V per side to allow for its resistances. Since the simple circuit has no voltage regulation then the output voltage will be too high without a load and will be too low with a full load.
ebp
Joined Feb 8, 2018
2,332
In general, the circuit is terrible.
The 555, as configured, has a duty cycle of about 0.28. This is unsatisfactory for driving a transformer and can rapidly saturate the core in a real transformer. Since the drive transistors are unprotected, one would blow up unless the input power is limited. The starting point must be a square wave.
Both FETs will be on simultaneously at each switching transition because there is no non-overlap time. In a push-pull converter this can actually be used advantageously, but care is required.
I'm assuming the voltmeters are part of a simulation and that the simulation is using a lossless ideal transformer. There simply is not enough information for anything but guesswork. What does the "2P3S" mean with regard to the transformer.
Assuming you are simulating this, you need to do a run that shows both voltages and currents. Name the nets to plots are labeled sensibly. Do a short run of 2 or 3 cycles only so detail can be seen, then a run for long enough to see what is happening after many cycles.
28,611
The circuit is conspicuously supposed to be a square wave inverter. There are plenty of uses for them.
My electric chainsaw runs well off a square wave inverter. So these things DO still have lots of uses. But just as a hammer is not a good tool for many things, so square wave inverters are not for every application.
