Hello!
I’m really just a beginner when it comes to electronics. I can do some soldering and have built a couple of keyboards.
Now to the point, we have an home exercise bike (Master B20). We bought it used and tested it once.
On the back of the display there’s an on/off button/switch. My three years old daughter somehow managed to remove this button (poking it with a stick I think).
You would think the button should end up inside the housing for the display. But after taking it apart the button is gone. It is completely gone, we have searched everywhere.
If I only had the button I would be able to fix it, but now I can’t really figure out how it worked. (And I don't even know how the button looked, if it was a switch or push button).
So the problem is that we can’t start the bike. I really don’t need a button for it (we only plug it in when we’re using it). So I thought I should be able to just solder a wire where the button was to close the cuircuit.
The problem is that there are five ”pads” (not sure if that’s the correct word).
And I don’t know which of these that should be connected.
I have tried to do some testing with a multimeter to see how stuff are connected. But I can’t find that any of these five pads has a connection to where the power supply comes in.
As I said, I'm really not good at this. But I upload some images of the pcb here and hope perhaps someone might give me a few hints.
Thanks!
Bellow are some images.
This is the back of the display where the on/off button was, when looking down you see these five pads labeled "ENCODE".
An overview
Here you see the "ENCODE" part above which the button was located.
A closer look
Thanks!
An overview
A closer look
