how to find garage key fob frequency?
Andrewlapham
Joined Aug 29, 2017
32
I moved into to a new rental property and was given one key fob for the garage. I thought I might clone it and use an Arduino to make some more but I cant track down the frequency its running on. I have been scanning with an RTL-SDR across the 300 - 433mhz range but nothing, any ideas on what to try next?
Alec_t
Joined Sep 17, 2013
15,149
Are there any numbers/codes/labels printed or moulded on the casing of the key fob or the reverse side of the circuit board?
Even if you know the RF frequency, the fob for a recent opener may be using a rolling code. How would you synchronise your clone with that?
Andrewlapham
Joined Aug 29, 2017
32
What does the other side of the PCB show? Some door operators use or used to use a SAW oscillator (https://www.microsemi.com/product-d...aw-products/3880-rf-microwave-saw-oscillators), and the ones I have opened were marked with a frequency. There is also an obvious antenna, which I don't see on on the side you show.
Yeah i was looking for a crystal or something to give some sort of indication but found nothing. the reverse side of the pcb doesn't help much but you can see the track that is used for the antenna but still doesn't help
AlbertHall
Joined Jun 4, 2014
12,640
There is a trimmer capacitor and to its left in the picture a black thing surrounded by three capacitors. The black thing has three terminals from the pcb rear picture.
I think the black thing is an inductor which, with capacitors forms a tuned circuit which sets the TX frequency so the only accurate way of getting the frequency is to measure it but as it will be some form of pulsed output when a button is pressed this will be difficult/impossible with 'normal' frequency meters. You might be able to do it with a spectrum analyser or a grid dip oscillator.
jpanhalt
Joined Jan 18, 2008
11,087
Are you sure you need the frequency? If in the US, consider getting a cheap, 2-button, programmable "universal" opener, and see if it works. You want an opener that can learn, not the older type that uses switches for the code.
Maybe you can work backwards? What brand of opener is in the garage? Apparently Genie are all 315 and 390 MHz. Chamberlain and LiftMaster may have their own preferred frequencies.
18,134
That's what I was going to suggest - get up on a ladder and read whatever you can off the motor/chain housing. A little searching on the model number should uncover both the frequency and how it works. Or just get a learning remote. My cars all have buttons that can learn your garage door code. They work great and have a larger range. I never use the opener that came with the opener anymore.
BobaMosfet
Joined Jul 1, 2009
2,211
@Andrewlapham The transmitter likely operates at 340Mhz, from what I've found regarding remotes and garage door openers that use that IC. The RT1762PN produces the control signals and modulates the carrier. You can see L1, VC1, and Several other capacitors which are used to tune it. I admit I'm a bit stumped without reverse engineering it, as I don't see X1 (crystal) anywhere-- It is possible this IC has one internally as a later revision of an earlier RT1762xN by RATO.
This is the ONLY document I could find thus far- and even it doesn't quite match:
I'm looking to see if I have a datasheet for the RT1762PN.
EDIT: I did not make the above drawing, I found it online.
Andrewlapham
Joined Aug 29, 2017
32
I couldn't find any datasheet for the chip anywhere. I was completely stumped too but then assumed that the chip must have had the oscillator built in. it would be great if you had a datasheet though. thanks for the frequency lead though i'll start scoping around the 340mhz range and see if I find anything.
jpanhalt
Joined Jan 18, 2008
11,087
I do not think the RT1762PN chip has the oscillator. This is probably the oscillator section with an RF NPN transistor:
Those components connect to the loop antenna. Here's a typical circuit from another garage door remote:
DickCappels
Joined Aug 21, 2008
10,662
Do you have a scope with FFT mode and a sampling rate of 1 GHz or more? Using a 60 MHz scope with those specs you can probably spot the signal unless it is half the scope's sampling rate or the manufacturer took liberties with the bandwidth rolloff.
The SDR scanner should have caught something.
Is the fob known to work?
Andrewlapham
Joined Aug 29, 2017
32
Yes it does work, I've tested the SDR with my car keys that run on 433Mhz and can see the signal so i know that the SDR and the Garage key are both functional.
Andrewlapham
Joined Aug 29, 2017
32
At this point I'm actually considering putting a servo next to the box inside to physically press the button lol
Andrewlapham
Joined Aug 29, 2017
32
What brand of opener/opener receiver is it? Your fob may be missing the FCC notice, but the receiver shouldn't be.
Its a Steel-Line. i will take the cover off today and have a look at the PCB but considering there is a tuning pot on the side of the case id assume that the circuit would be similar to the fob as in the oscillator may be made up of passive components.
BobaMosfet
Joined Jul 1, 2009
2,211
The problem is that the above is a variable capacitor, and I cannot find a transistor anywhere on the PCB (either side). Can the TP get another shot of the above, better lit?
jpanhalt
Joined Jan 18, 2008
11,087
A tuning pot? I suspect that is not for tuning but for setting something like obstruction sensitivity, light timer, closing distance, and so forth.
Maybe this will help focus the search for operating frequency:
Now you know where to look with your SDR.
As for the transistor, the picture I posted in #10 clear shows something consistent with a T0-92 when lightened.
Andrewlapham
Joined Aug 29, 2017
32
