Is there a way to find the current limit on the secondary side of a power transformer. Because i got one from a pcb, and want to know the current limit for a project.
One rough way is to load it with a resistive load until the voltage drops about 10%.
That should give you a reasonable limit for the RMS current.
The maximum DC current from a connected full-wave rectifier-capacitor filter would be about 60% of that.
Weigh it and one similar that you know about. Then estimate using watts per pound. Measure the output voltage, reduce that number by 10% like crutschow said, and divide the watts by the voltage.
Crude, but better than a complete guess.
Then measure the temperature after you have it running something. If it's too hot to hold your hand on, you're probably wrong.
