How to find a replacement ribbon cable
Yami
Joined Jan 18, 2016
354
Hi, I have a busted ribbon cable. I have been searching online with numbers and letters written on the cable with no luck. I have attached a picture of the cable. Thanks in advance for the help.
P.s - It would be great if you could explain to me all the writing on the cable.
abrsvc
Joined Jun 16, 2018
167
You might have better luck describing where the cable is used. Make and model of the unit and where it is used will be helpful. The numbers on the cable describe the cable itself and not the "assembly". As an "assembly", I am referencing the length and end connections. The raw cable numbers are what you posted.
Yami
Joined Jan 18, 2016
354
Thanks everyone, finding out the actual name of this type of cable has helped me a lot :D.
This is from a Yamaha Motif keyboard.
