I have a doubt. Why is Rs* value so low in this circuit?I use a 12VDC 1A cheap wallwart to charge my 12V 7Ah SLAB.
You can use it directly or you can build this 12V battery charger that outputs about 14.5V
OK. I am using a 12/24 V, 10A solar charge controller (without MPPT) to charge a lead acid battery of 12V, 1.2 Ah battery from a 12V, 20 W solar panel on a bright sunny day with outside temperature ranging from of 31 degree Celsius to 37 degree Celsius. I hope the specifications are right and everything goes on smoothly.If you want a quick charge you need a charge controller. Trickle charging takes much less attention.
In the lighthouse system I mentioned we're only pumping a max of 7 or 8 amps into batteries rated for 200 AH. That keeps us topped off for the few days we actually load the system outside of a few spotlight every night.
The USCG has a separate very sophisticated system to keep their batteries charged to run the light itself. We just use ours for some housekeeping when we are there a few days a year.
You don't get free power out of thin air - if you're converting to 4x the voltage; the 12V part will draw at least 4x the current you're taking at 48V.Its a high gain converter that converts 12V to 48V. I need to demonstrate this.
Hi,Charging a lead acid battery from a solar is actually quite simple when the system is balanced. Just get a solar panel with a low output, say 100 mA max, and connect it thru a diode to the battery. The diode may already be in the panel too.
We do this on a lighthouse I volunteer at charging two deep cycle marine batteries directly off about 100 watts from the panels. No monitor, no limited, nothin. They chug along for several years like this
{Pre coffee reply}Hi,
Yes, quite simple if you dont mind doing it not exactly right. Connecting a solar array directly to a battery will charge it, but without specifying the voltages there will always be energy lost because the array wont be running at it's max power point. The max power point is the operating condition of the solar array when the maximum input power is transferred to the output so we get the maximum power out of the array and thus the maximum energy for a given insolation.
Hi there,{Pre coffee reply}
Meaningless pedantic gibberious, unless millions of garden solar night lights are also not exactly right.
Hello again,24 gazillion watt hours wasted? So what? Did they go off to Jupiter or something? I'd point out your estimate of waste has an error of 24 in it but that would be cruel.
MPPP tracking has it place but charging a battery is not one of them, because what happens to all your maximum power once the battery is fully charged?
Hint: the power gets wasted. MPPP only makes sense where there is always a load greater than the panel can produce.
In a garden light you would never get better efficiency with a switching power supply to track max power over a single reverse bias diode to charge a single AA Ni-Cad battery, and besides, it's unnecessary as the battery gets fully charged each day.
Your argument is similar to the one (perhaps not quite true) of the physicist hired by Edison to determine how to get the maximum power to his customers. The physicists answer was technically correct but missed what question he should have been answering all along.
Hi,I suggest you start your own thread to clear up your misunderstandings and stop trolling this one.
Final answer.
