Hi to all,
I have to drive two N channel mosfet connected back-to-back in order to work as general switch.
As you can see in the attached file, I've found some solutions (N channel mosfet switch driver) proposed by the most famous IC manufacturers (MAXIM INTEGRATED for example), but the problem is that all this type of ICs provide a protection against reverse polarity! In my application instead the reverse polarity shall be permitted!
How can I solve the problem? Could you suggest me an IC without the protection against the reverse polarity? Or could you suggest me an alternative electronic schematic ?
Referring to the attached file, the maximun value of Vin is 36V
