How to draw in a 16x16 matrix
ericgibbs
Joined Jan 29, 2010
21,522
hi EG,
Welcome to AAC.
Have you read this technical data from your link.?
E
Added:
The Arduino UNO cable connections
UPdate;
From other user notes:
These LED matrix are very nice with good build quality and great packaging. The two I received are RED color LED's only. The product description does not say what color they are. Might get different colors, who knows? There are 3 solder pads to set I2C address variations. The base address is 0x70 (hex.) Runs on the Adafruit LED Backpack library (for Arduino) without modification. Five stars for the product. I have purchased five different items from keystudios so far and all have been great.
Ian Rogers
Joined Dec 12, 2012
1,136
If you want small to use the 16x16 matrix as a little screen to view animations and pictures, you need to grab a driver that has been written for it.. I have a small driver that I used on a pic16f877a that displayed anything I wanted onto a 16 x 32 or a 8 x 32 pixel matrix using 74H595 as line drivers.... I updated the LED matrix from an interrupt and used a shadow screen buffer to draw on..
What platform are you going to use???
Eudécio Gabriel
Joined Jun 24, 2018
15
I want to know how does the hexadecimal code to turn on the LED'S in the matrix works!
unsigned char Display_Buffer[2];
const unsigned char Word1[1][32] =
0xFF,0xFF,0xFF,0xE1,0xC0,0x80,0x80,0x80,0xC0,0xE0,0xF0,0xF8,0xFC,0xFE,0xFF,0xFF,
0xFF,0xFF,0xFF,0x87,0x03,0x01,0x01,0x01,0x03,0x07,0x0F,0x1F,0x3F,0x7F,0xFF,0xFF,/*"C:\Users\Lin\Desktop\心.BMP",0*/
const unsigned char Word2[1][32] =
0xFF,0xF8,0xF0,0xE0,0xC0,0x87,0x86,0x84,0x85,0x86,0x87,0xC0,0xE0,0xF0,0xF8,0xFF,
0xFF,0x1F,0x0F,0x07,0x03,0xE1,0x61,0xA1,0x21,0x61,0xE1,0x03,0x07,0x0F,0x1F,0xFF,/*"Unnamed file",0*/
As you may know each interaction with the hexadecimal code turn on or turn off a sequence of LED's.
PS: It doesn't includes the LED CONTROL library as usual.
