How to do SCR Firing after a time delay
moonlystar1111
Joined Feb 1, 2024
106
I want to create a circuit where an SCR is fired whenever the comparator output goes high. I want to add a delay circuit, causing a delay of 2msec. (Using cap and resistor)
Whenever I'm connecting comparator output to SCR, SCR input gets flipped. Im not getting why it is happening like this.
Also, can a cap of .1uF and Res of 20k will do that? , I saw the pulse is not delayed when I did this. Please guide me through this.
k1ng 1337
Joined Sep 11, 2020
1,038
Hi, can you rephrase your goal as a bullet list or flow chart? I'm not sure you need a SCR or the second op amp based on your description.
k1ng 1337
Joined Sep 11, 2020
1,038
I want to connect it with a relay. When Scr fires, relay will be activated.
Will be waiting for your reply
Can you tell me more about the input pulse? I see the parameters you set in V3 of your schematic but I would like to understand how this relates to the 4-8V specification you gave in post #3 and why this is important.
Ian0
Joined Aug 7, 2020
13,264
Your SCR appears to short out the power supply. After that your reference voltage will be wrong and nothing will power your comparator.
An LT1017 can only source 250uA. Your SCR needs a gate current of 15mA. It's never going to trigger.
moonlystar1111
Joined Feb 1, 2024
106
Okay so I was working on a complex schematic from which I have omitted some part to make it more understandable. I guess just to understand the functioning of an scr, we can omit the higher and lower threshold also.
My apologies for the late reply, i was busy with some other stuffs.
moonlystar1111
Joined Feb 1, 2024
106
What’s the point of the delay? The relay is going to take a few milliseconds to close.
I added delay because scr might get fired because of some noise or voltage surges. I don't want the scr to fire if the surges are within the given time limit i.e; 2msec.
moonlystar1111
Joined Feb 1, 2024
106
Okay I will attach other comparator compatible with 15mA output current.
