How to detect arduino board through USB using android phone
Don_Fila
Joined Nov 26, 2021
172
i was desingning an app that can communicate between android phone and arduino board. but whenever i connect the android device to the arduino the USB is detected and working but it says No arduino board detected. Below is the detection code, I really need help and any help from you will be highly appreciated.
C-like:
private void detectConnectedArduinoBoard() {
if (usbManager == null) {
Toast.makeText(this, "USB manager is not available", Toast.LENGTH_SHORT).show();
return;
HashMap<String, UsbDevice> deviceList = usbManager.getDeviceList();
if (deviceList.isEmpty()) {
Toast.makeText(this, "No USB devices detected", Toast.LENGTH_SHORT).show();
return;
for (Map.Entry<String, UsbDevice> entry : deviceList.entrySet()) {
UsbDevice device = entry.getValue();
if (isArduinoUnoDevice(device)) {
// Display Arduino Uno board info
                String info = "Arduino Uno board detected\nManufacturer: " + device.getManufacturerName() +
"\nProduct Name: " + device.getProductName() +
"\nVendor ID: " + device.getVendorId() +
"\nProduct ID: " + device.getProductId();
Toast.makeText(this, info, Toast.LENGTH_LONG).show();
return;
} else if (isArduinoNanoDevice(device)) {
// Display Arduino Nano board info
                String info = "Arduino Nano board detected\nManufacturer: " + device.getManufacturerName() +
return;
} else if (isUSB2SerialDevice(device)) {
// Display USB2.0 Serial device info
                String info = "USB2.0 Serial device detected\nManufacturer: " + device.getManufacturerName() +
return;
Toast.makeText(this, "No Arduino board detected", Toast.LENGTH_SHORT).show();
// Method to check if the connected device is an Arduino Uno
    private boolean isArduinoUnoDevice(UsbDevice device) {
// Replace these vendor and product ID values with the actual IDs of the Arduino Uno
        return device.getVendorId() == 9025 && device.getProductId() == 67;
// Method to check if the connected device is an Arduino Nano
    private boolean isArduinoNanoDevice(UsbDevice device) {
// Replace these vendor and product ID values with the actual IDs of the Arduino Nano
        // Example IDs for Arduino Nano
        return device.getVendorId() == 1027 && device.getProductId() == 24577;
// Method to check if the connected device is a USB2.0 Serial device
    private boolean isUSB2SerialDevice(UsbDevice device) {
// Replace these vendor and product ID values with the actual IDs of your USB2.0 Serial device
        // Example IDs for USB2.0 Serial
        return device.getVendorId() == 1234 && device.getProductId() == 5678;
// Register BroadcastReceiver for USB device attachment and detachment events
    private void registerUSBReceiver() {
usbReceiver = new BroadcastReceiver() {
[USER=54416]@override[/USER]
            public void onReceive(Context context, Intent intent) {
String action = intent.getAction();
if (UsbManager.ACTION_USB_DEVICE_ATTACHED.equals(action)) {
// USB device attached, trigger detection
                    detectConnectedArduinoBoard();
} // USB device detached, no action needed in this case
                // Device detachment might not require any action in this context
IntentFilter filter = new IntentFilter();
filter.addAction(UsbManager.ACTION_USB_DEVICE_ATTACHED);
filter.addAction(UsbManager.ACTION_USB_DEVICE_DETACHED);
registerReceiver(usbReceiver, filter);
// Unregister the USB BroadcastReceiver
    private void unregisterUSBReceiver() {
if (usbReceiver != null) {
unregisterReceiver(usbReceiver);
Ya’akov
Joined Jan 27, 2019
10,295
return device.getVendorId() == 9025 && device.getProductId() == 67; }
In the code, detection is entirely dependent on the USB Vendor and Product IDs, and there are only tests for the Uno and the Nano—which apparently don’t even have the correct numbers for the IDs.
1. Have you replaced the examples with real data?
2. Are you using an Uno or a Nano for testing?
Don_Fila
Joined Nov 26, 2021
172
Since it isn't easy for me to get those ID's I got that online and think that is why it isn't working.
Yes I am using Arduino Nano
