Hi everyone, now I under designing the ESD sensor circuit.
so the circuit concept is when the ESD (8-30kV) event occurs, the ESD sensor circuit (away from ESD point around15cm) have to detect and send signal status to the MCU.
I already made and tested the circuit prototype but it not work
I doubt the antenna(make from normal wire) and tank circuit (LC) cannot receive electromagnetic or maybe from another causes?
Do you have any advice for this circuit? or Do you have other circuit to detect the ESD ?
Thank you!
Thank you!
