I made a circuit that counts from zero to nine..but I can't do that....and I want to truth table and karnaugh map of the odd counter...How is designed ?What have you done so far to solve this problem?
How about writing the numbers in binary to see if there is a pattern.
okey thanks for the everythingI asked you to write out the numbers in the sequence, one underneath the other, for a reason. Do it and you will see a pattern that suggests an obvious solution. If you don't see the pattern immediately write the boolean equations for each column. It will come to you eventually.
No, I don't think soSo, were you able to solve the problem?
and I apologize to all for my terrible English..So, were you able to solve the problem?
I must see one bit in the seven segment display.Did you write out the numbers 1, 3, 5, 7, 9 in binary? If you did that can you show us what it looks like to you?
I don't think so. You have 2 separate problems which you can solve independently.I must see one bit in the seven segment display.
