I've never used them at all, never built anything with valves in but have been thinking of playing around with some just to get the knowledge, I can't tell you how many valves I smashed as a kid so they'd go "pop" in the street, I likely destroyed some rarities too - like an idiot.Gosh, I haven't used one of those since 1975! Used to have a pair in push-pull at 144MHz pumping out about 400W...
Electrically, not that difficult. Mechanically, the forced air cooling was a pain, the components mentioned in the data sheet were way outside my means as a teenager, though I was lucky then to find some ex-Army surplus parts. All too often the tubes had been pulled from ex-military kit but the housings were scrapped... it was the housings that were valuable!I've never used them at all, never built anything with valves in but have been thinking of playing around with some just to get the knowledge, I can't tell you how many valves I smashed as a kid so they'd go "pop" in the street, I likely destroyed some rarities too - like an idiot.
That's a serious project, quite a lot going on there. May I ask your age? I'm 64 and as a kid (say thirteen or so) I often got given old copies of Practical Wireless and I recall that there was often several transmitter projects a year in that magazine. A very good mate of mine attended Riversdale College in Liverpool for two years in the late 70s (long closed down now) to study Marine Radio and Radar, ended working in Saudi for a few years for Marconi doing radar and stuff.Electrically, not that difficult. Mechanically, the forced air cooling was a pain, the components mentioned in the data sheet were way outside my means as a teenager, though I was lucky then to find some ex-Army surplus parts. All too often the tubes had been pulled from ex-military kit but the housings were scrapped... it was the housings that were valuable!
Here's an example that is quite similar to what I built....
I'm 66. In the early 70's, from about 13 onwards, I was very into amateur radio, primarily on the 144MHz/2m band. The power amp was built, circa '75-76 for a radio competition. I belonged to a local amateur radio club in north London (and the local motoring/rallying club as did many other members, the two interests went side by side), and we used to go up to Yorkshire and set up huge aerial masts in farmer's fields and see with how many stations, how far and how rare, we could communicate. Sadly I have no photos of the amp, which was a collaberative effort with other club members (from memory we built 3 in total), or the competitions, just fond memories. In 1979, after I graduated, I got a design job at the Electronic Warfare Labs of Plessey Avionics, working under/with several club members on ground-to-air comms, with a trend to semiconductors, notably early high-power Motorola RF MOSFETs. Once it became a job, my interest in amateur radio, but not electronics in general, waned, and cars and girls took over....That's a serious project, quite a lot going on there. May I ask your age? I'm 64 and as a kid (say thirteen or so) I often got given old copies of Practical Wireless and I recall that there was often several transmitter projects a year in that magazine. A very good mate of mine attended Riversdale College in Liverpool for two years in the late 70s (long closed down now) to study Marine Radio and Radar, ended working in Saudi for a few years for Marconi doing radar and stuff.
I only the other day from answers to my thread did I discover how you can boost the current from an op amp with transistors. A possible approach? Certainly more elegant than paralleled op amps.Body
I am working on a power electronics project where I need to mix a 12V DC signal with a 1V AC signal and then amplify the output to achieve 20A while maintaining a bandwidth of 100 MHz. My current approach involves using operational amplifiers, but I am unsure about the best way to design the circuit to handle such high current without distorting the signal.
<snip>
If taken literally, this really means you need to use vacuum tubes. All opamps use transistors as their active device.Avoiding Transistors: Based on guidance and an application note, using transistors directly is discouraged due to potential oscillation issues.
Also I'm not English. If I correctly understand Your problem: Take a stable 12V 20A power source with necessary power stability response (here your bandwidth 100MHz) AND try to modulate (inject, if You like. Yes, reverse engineering) circuits voltage stabilizing part with Your white noise. MRI would like to provide more context to clarify my project and the challenges I am facing, without disclosing sensitive details.
Project Background:
The project originated from the need to accurately test electrical disturbances, such as noise in power supplies of high-frequency electronic boards. The current testing methods lack precision in simulating predefined noise profiles, which limits the ability to reliably evaluate the performance and robustness of these boards under specific noise conditions.
Current Challenge:
Existing methods use transformers and the "sense" function to simulate electrical disturbances, but these have significant limitations:
Transformers: Can induce unwanted voltage oscillations and surges, and often fail to reproduce the full spectrum of electrical noise.
"Sense" Function: Useful for controlling input voltage, but can lead to stability issues and potential damage to the boards being tested.
Pi Filters at Input: The boards have Pi filters at the input, which can contribute to oscillation issues when noise is injected.
Project Goals:
Develop a Noise Injection System: Create a setup that includes two main electronic boards - one to generate noise according to a defined frequency and amplitude profile, and another to inject this noise into the standard power supply of the test benches.
Ensure System Stability: Design the system to avoid unwanted side effects such as oscillations or voltage spikes that could damage the boards under test.
Key Specifications:
Noise Profile: Inject white noise with a frequency range up to 100 MHz and an amplitude around 10^3 µVrms/√Hz into a 12V power supply, achieving a 12V output with 20A.
High-Frequency Performance: Maintain a high bandwidth to accurately simulate operational conditions.
I am open to exploring any configuration or approach that meets the project requirements and overcomes the limitations of current methods.
I apologize if my explanation is not perfect; it is based on my current understanding. This is really the maximum detail I can provide. I appreciate the constructive discussion and any guidance or suggestions you can provide to help me advance in my project.
White noise from DC to 100mhz, there will be almost zero energy in the 50mhz to 50.01mhz area so measuring the output is hard. You are injecting a signal at all frequencies. I inject a small signal at a frequency that moves from DC to 100mhz. Because all the energy is at one frequency at any moment, the signal is easy to see, and the power used to inject is very small.Noise Profile: Inject white noise with a frequency range up to 100 MHz and an amplitude around 10^3 µVrms/√Hz into a 12V power supply, achieving a 12V output with 20A.
I have some issues with this element of the ongoing problem statement.Noise Profile: Inject white noise with a frequency range up to 100 MHz and an amplitude around 10^3 µVrms/√Hz into a 12V power supply, achieving a 12V output with 20A.
With which component do you make the mixture of the tension 12V 20A and the noisy signal?Also I'm not English. If I correctly understand Your problem: Take a stable 12V 20A power source with necessary power stability response (here your bandwidth 100MHz) AND try to modulate (inject, if You like. Yes, reverse engineering) circuits voltage stabilizing part with Your white noise. MR
Thank you for your suggestions regarding the approach of frequency sweeping versus white noise injection. Currently, I generate the white noise using MATLAB to create a signal that conforms to a specific frequency template, and then I perform an FFT to analyze the spectrum. This method allows me to cover the range from 50 Hz to 100 MHz, in accordance with the requirements of my project.White noise from DC to 100mhz, there will be almost zero energy in the 50mhz to 50.01mhz area so measuring the output is hard. You are injecting a signal at all frequencies. I inject a small signal at a frequency that moves from DC to 100mhz. Because all the energy is at one frequency at any moment, the signal is easy to see, and the power used to inject is very small.
How do you make white noise at DC? Usually, we do not test below 50hz.
I know this has been said before, several time.
Thank you for your perspective on how I could have framed my question. Initially, I hesitated to present my query in such an open-ended manner because it seemed too much like asking for a complete solution without demonstrating my own efforts. However, I have been conducting research on my own, and my intention was to find out if there exists a specific application or solution based on my conclusions. This approach allows me the possibility of being wrong, which is part of the learning process. My goal isn't to have you solve my project without any input from my side but to verify and refine my findings through expert feedback.The question could have been presented like this:
I need to test a system to discover the effect of noise on the power supply input of a system. The power supply voltage is "VV" volts DC, and the current is "AA" amps. The noise test specifies "Noise frequency spectrum limits" at a level of "NV" volts relative to the power source negative side.
What is the best (cheapest?), (Fastest), ( Most accurate) method that somebody has experience with??
The only product information given is the voltage and the current, which do not really give away much detail.
Telling us that you needed an amplifier to provide both DC and AC greatly limits the options.
