How to decipher 18650 battery labels?
Tonyr1084
Joined Sep 24, 2015
9,744
Labeled as:
MOLI ICR-18650M
U72 2E617 02
What's their amperage? I'm finding conflicting information on Google. 2800mA, 4000mA and 5000mA.
dl324
Joined Mar 30, 2015
18,330
From my limited experience, the capacity is plainly marked on the label:
These were AliExpress "specials" and it seems that 9900mAh means more like 3000mAh...
And more:
Tonyr1084
Joined Sep 24, 2015
9,744
Those are pretty close. I also found the 2800mA rating. But because the label didn't match exactly I wasn't sure. I'm thinking the U72 or the 2E617 might be some sort of date code. When one doesn't know - the best thing to do is to ask.
@dl324 Those you can buy are typically marked. These are marked only as stated in post #1.
Audioguru again
Joined Oct 21, 2019
6,826
Cheap batteries are fakes or worse. Name Brand batteries do what their labels say they do.
The mAh is not the maximum allowed current, instead it is how much time a reasonable current will last for one discharge.
There are battery tests online that show many no-name-brand batteries fail and are junk.
Beware! An 18650 cell is Lithium that is dangerous. If a poor quality battery or charger is used then you might have a spectacular explosion and fire.
Tonyr1084
Joined Sep 24, 2015
9,744
These batteries came out of a Toshiba laptop. It's not likely they are cheap knock-offs.
@bertus -thanks for the chart. I'll save that in my archives.
