How to CRO to see the read and write bytes of eeprom?
smanisrinivas
Joined May 11, 2017
hi ,
I am using i2c communication protocol ,can any one tell me how to connect CRO to see the read and write bytes of eeprom .
thank you
Sensacell
Joined Jun 19, 2012
3,789
If you are using an analog CRO, it's almost useless, the data will smear into an un-readable mess.
For a digital scope - setup two channels: SCL and SDA, trigger on the SCL line.
LesJones
Joined Jan 8, 2017
4,544
I did this recently while trying to write code to do I2C communication with a INA219 (TI voltage and current sense IC) I added a few lines of code to generate a pulse on a spare I/O pin of the microcontroller to trigger the scope just before the code that reads a byte from the device. This was using a PIC12F1840. I can post the source code if it would be any help to you.
Les.
