How to control the amplitude of output voltage in wien bridge oscillator?
wldb737
Joined May 6, 2018
I want to change the amplitude of output voltage in wien bridge oscillator depending on the value of sensor. (maybe pressure sensor)
What element decide the amplitude of output????
DickCappels
Joined Aug 21, 2008
10,661
It depends on how the amplitude is stabilized. There is more than one method.
Please post your oscillator circuit or a link to it.
wldb737
Joined May 6, 2018
This is my circuit.
Depending on what switch is closed, ouput voltage's frequency is changed.
Then, how can I change the amplitude??
Is there any way to change amplitude using variable voltage? (pressure sensor's output is voltage)
DickCappels
Joined Aug 21, 2008
10,661
The output amplitude is function of power supply voltage and opamp characteristics.
You could try controlling the amplitude by varying the power supply voltage, or you could try a circuit like the one below,, in which case you would put a resistor in series with the anode of D1 and sum current into the anode of D1 through another resistor to modify the ampltude.
https://rustybolt.info/wordpress/wp-content/uploads/2012/01/WBO-JF10ZL.gif
The cleanest solution is probably to pass the output of the unmodified oscillator through a gain control circuit such as a transconductance multiplier or multiplying DAC.
(pdf) MT-079: Analog Multipliers
wldb737
Joined May 6, 2018
Thank you, very much.
But, actually.. I can't use diod or transister in this project TT (It's my professor's rule..)
So I can not use VCA.
I tried to vary the power supply voltage using voltage divider and variable resistor, but there were some errors ..
