How to connect this symbol
35,299
Except that the NPN BJT is in the cut off region. You are not going to get much of a signal from an antenna to drive that transistor on.
A properly biased FET would be a better choice.
Tell us what you are trying to do. What frequency signal are you trying to amplify?
dante_clericuzzio
Joined Mar 28, 2016
246
How do we determine how much signal (signal frequency) an antenna can generate? For example i made a circuit using crystal 12 Mhz and then amplify to 24 Mhz....i want to this amplifier to help the antenna generate some good frequency output
