How to connect piezo to amplifier module
oknimie
Joined Mar 12, 2018
16
Hello, I am trying to connect piezo(s) to amplifier module, such as adafruit MAX98306 and speaker. However it is not working. When I connected piezo to sound mixer or zoom H4n, it picked up the sound. I was wondering if anyone had any suggestions on the best type of amplifier module to use, preferably small ones.
Thank you in advance!
RichardO
Joined May 4, 2013
2,270
Which Piezo transducer are you using?
Normally they only have a few hundred picofarad of capacitance. This capacitance is a very high impedance at audio frequencies. This means that you need an amplifier with a really high input impedance to get the low frequencies.
oknimie
Joined Mar 12, 2018
16
Hi RichardO,
I am using the 20mm diameter piezo (the common one. But I am thinking of using 5mm diameter also.
sghioto
Joined Dec 31, 2017
8,766
Connect the output of the preamp to the input of the MAX98306 if that is the audio chip you want to use. The MAX98306 is a dual amp designed for stereo output.
SG
RichardO
Joined May 4, 2013
2,270
Please post the specifications for your Piezo's. I think you will find that they only have about 1000pF of capacitance. to get a 20 Hz lower frequency cuttoff you will need about 10 Meg ohms input impedance on the amplifier.
The MAX98306 is designed for line level input. You will need a preamp.
SG
https://www.sparkfun.com/products/9816
This amplifier only has about 15 K ohms of input impedance. :(
You need either use an op-amp with a FET input or make a buffer amp using a J-FET. If you make a buffer amp you can use the circuit like used in an electret microphone.
Speaking of electret microphones... A real microphone will have much better frequency response than a Piezo element. Look at the frequency response of your Piezo transducer to see what I mean. Note that it has a very sharp peak in the frequency response and lots of other peaks, as well.
ian field
Joined Oct 27, 2012
6,536
Hello! I am using it as a contact microphone.
It will work with the special JFET in an electret mic capsule. You might not even need any more amplification than that, but its not difficult if you do.
Common or garden JFETs like the 3819 sort of work, but salvaged from a capsule is better.
oknimie
Joined Mar 12, 2018
16
Hi Richard, I am first planning to use RS Pro Maximum of 30V Pk-Pk Panel Mount piezo Buzzer, Maximum of 9500 Hz, 12mm diameter and 0.22mm height with 8nF capacitance.
I found a pre-amp http://www.stompville.co.uk/shop/34-phantom-piezo-preamp-v2.html. Would this work?
Thank you for your suggestions!
oknimie
Joined Mar 12, 2018
16
Hi Ian,
Thank you, I will look into JFET. When you say special JFET in an electret mic capsule, do you mean JFET in a piezo contact mic capsule or I take out an existing JFET in electret mic capsule and connect it to piezo?
ian field
Joined Oct 27, 2012
6,536
Hi Ian,
The JFET in a mic capsule, I made contact mics/vibration sensors with various piezo elements. The JFET settles close enough to bias a TL431, a resistor provides DC nfb to stabilise the operating point, but you have to split the resistor and add a capacitor to shunt AC nfb - so much gain it could demonstrate that some non polarised capacitors are microphonic. The long thin piezo from a lighter produces huge output.
oknimie
Joined Mar 12, 2018
16
It appears that it will work. But for a little effort, @Ian-field has a cheaper solution.
Hi Ian,
Thank you very much, I will try it out!
