How to charge battery pack ?
Rufus Chucklebutty
Joined Mar 23, 2019
70
How do i charge this battery pack from an imax RC charger ?
I have put 7..5 v on it for a few minutes to get the voltage back up but I keep getting an error message on the charger .
wayneh
Joined Sep 9, 2010
18,175
After you've applied 7.5V for a while, disconnect the charger and measure the pack voltage. If it's well below 7.5, it's possible a cell has failed and it's not taking a charge anymore.
Sometimes you can get some more life out of the pack by cutting it open to replace the bad cell, but you my be better off just building yourself a new one or of course, replacing the pack.
28,450
Are you able to measure the pack voltage after the charging attempt??
You can keep trying to use that charger, but feel the battery pack and stop if it gets more than slightly warm.
28,450
Without having any hint about that error message, I am making a guess, which is that the battery pack is not the model that the charger is designed to charge. In that case, you might "be out of luck."
A very common rechargable battery failure is being unable to accept a charge, in which case the current will not be what the charger expects to see.
So we need two answers:
First: What is the error message?
Second: is this the model of battery that the charger is intended to charge??
