How to calculate the input current through my buck converter?
Electronic_Maniac
Joined Oct 26, 2017
253
Hi all,
I have a buck converter , TPS54260.
My input voltage range is 8-16V and my output is 5V and 550mA.
How should I calculate my input current to the converter?
I tried using the efficiency power equation approach but unable to find.
Can you please explain me how to find the input current?
MrSoftware
Joined Oct 29, 2013
2,273
Is your load steady? Scope the input and use caps to smooth it out as much as possible. Put a small resistor in series, maybe a 1/4 ohm and measure the voltage across the resistor. Use that to calculate the current. If the voltage is not smooth then you can use an averaging meter to get the average current, and use a scope to get the peak current. Someone please correct me if there's a better way.
