The Electrician
- Joined Oct 9, 2007
- 2,970
Imagine you had this fraction:Hi again,
I have added the two real parts together (which are in the left and right sides of the imaginary part, in the above calculation) and also keep separate the imaginary part. I didn't understand what is the wrong with that.
\(\frac{1}{3+2 j}\)
You can't just split the denominator and get this:
\(\frac{1}{3}+\frac{1}{2 j}\)
You have to rationalize the denominator.
View this video for the procedure:
Part of your problem is that you must derive the transfer function of your circuit in post #1 yourself. Once you have the transfer function you can then calculate the attenuation. Do you know how to analyze circuits that contain inductors and capacitors?This transfer function just I have taken from the video tutorial which is shown in post #15.
I haven't found any transfer function of 4th order RLC circuit. So, please could you provide me the transfer function of 4th order, so that I will do the mathematical calculation for the attenuation of filtered circuit.
If the circuit you gave in post #1 were composed of 6 resistors (no capacitors, no inductors) would you be able to calculate the voltage at the right end of it all with a voltage of V1 volts applied by the source at the left end?
If you can do that, please do it and show your work. For this let L1 = 2 ohms, C1 = 3 ohms, L2 = 4 ohms and C2 = 5 ohms.
