MisterBill2
- Joined Jan 23, 2018
- 28,511
OK, if the motor does in fact use hall effect sensors and if the sensors do really have the described signals, then it seems that soehow the drive signal is getting into the measurement connection. That is probably due to a problem with the common connection to he hall sensors. It would certainly not be the first time that has happened.
So once again I am going to suggest a capacitive connection with a wire wrapped around one of the motor's three coil drive wires and referenced against the supply negative line. The sweep rate should be slow enough to display a repeating variation in the duty cycle of the PWM frequency, rather than synchronizing on that PWM frequency.
