How to build a laser
Status
Not open for further replies.
28,405
One other rather brutal fact that may not have been mentioned is that Gallium ARSENIDE is rather deadly toxic. In fact, a whole lot of the chemicals and gasses used in the semiconductor business are very toxic, as in "breath once and die" toxic. Totally aside from the vacuum chambers and pumps and a whole lot of expensive hardware there is that toxic chemicals problem. But if you really want to make a laser, get the rod of laser material and build the assembly with a lot of laser diodes to pump the big laser crystal. That works, and it is not toxic, and nobody will have a clue what you are going to use the parts you buy for. And if done right you will have a laser strong enough to burn small holes in people and things and be quite dangerous. But not at all toxic!
I told him that in #22.
It's far more difficult to fab than a simple transistor or crude IC substrate.
WBahn
Joined Mar 31, 2012
33,253
I'm not saying you aren't employed. I'm saying you prob never built a laser.
Well, I HAVE built a laser -- it was a requirement of one of the undergraduate physics labs I took -- and I know several other people that have, as well. One of them owns a business making lasers and equipment that uses them.
What is apparent is that you are NOT interested in actually seeking assistance in how to do this, but rather just in arguing. Otherwise, it would have become apparent to you that, for whatever reason, you are not going to find the assistance you seek on this site and would have looked elsewhere a LONG time ago.
This thread has served any reasonable purpose and is being closed.
Status
