How to build a laser
Status
Not open for further replies.
Nirelan
Joined Nov 5, 2018
39
I have seen laser kits online, but they are basically just premade and you hook up the power circuitry to it. How would you make a simple laser from the ground up?
Tonyr1084
Joined Sep 24, 2015
9,744
What's a semi-conductor laser? Are you trying to etch a PCB using a laser? If so - watch out for your eyes. Would help us if we knew your goal(s).
Nirelan
Joined Nov 5, 2018
39
What if you took the gallium arcenide out of the laser in a dvd drive? Could you make your own enclosure for it and power it yourself?
dl324
Joined Mar 30, 2015
18,453
There's no way to do that and still have a functioning LED.
I wouldn't consider that building your own "from the ground up". You can buy laser diodes from many sources.
Building your own laser diodes would require millions of dollars worth of equipment and people who had some recipes. You can use old equipment because LEDs can be made without resorting to submicron features.
atferrari
Joined Jan 6, 2004
5,022
Not that I am questioning you, but why can't you get gallium arcenide yourself and do it?
Hola Nirelan,
Having a minimal idea of who dl324 is, I would tell that he he has some chances to get gallium arsenide and know what to do with it but you could not even that.
Please read one or two detailed explanations of what the laser effect is and how it is actually implemented and you could have your own question answered by yourself.
Unless what you call "build" is assembling an application of sorts, using a laser diode you got salvaged from old equipment.
Nirelan
Joined Nov 5, 2018
39
I have read a lot about it and understand the book part. I just feel that its something you need hands on experience to understand in a practical way.
dl324
Joined Mar 30, 2015
18,453
If you take the GaAs out of the diode, you'll ruin the crystalline structure and the LED while you're at it. If you just want the materials, buy them. I doubt that any laser diode manufacturers manufacture their own wafers.
Nirelan
Joined Nov 5, 2018
39
Ive read about how a laser works atferrari, I just think that doing it irl is going to be tons different than a book. Like for example, we all prob understand what a lens does, but I doubt most people could ground glass and make one by hand without practice.
spinnaker
Joined Oct 29, 2009
7,830
Here is a question. Why on earth would you want to build your own laser when they can be so cheaply purchased? You might even have one in an old DVD or CD player.
And the correct term is laser diode not "semiconductor laser" that is used in a DVD player.
Status
