Does anyone here know if there are any regulations or best practices regarding how protective earth wires should be fastened to connectors on a pcb to prevent it from coming lose? I.e. screw clamp terminal with ring tongue crimp, spring clamps, or something like this? In larger cabinets, regular earth bars are used, but what is normal to use on a PCB?
I'm making a module contained within a small plastic enclosure, that will control a couple of solenoid valves etc. The valves' PE wire will go to this earth bonding point within the module.
Many thanks!
Many thanks!
