Hi everyone, I'm Brazilian and this is my first post here. I'm graduating in Mechanical Engineering. In Brazil, in order to conclude our graduation, we have to build a project. I'm working in ANC (Active Noise Control) for ducts. The Professor that orientates me, asked to build a sound amplifier so as to amplify the signal that leaves my Arduino. I based on this video (link
) and it perfectly worked. I used a signal generator and an oscilloscope to confirm that. However, my Professor also said I had to simulate the circuit because it's an academic work. The problem is that I'm using Proteus and I couldn't find the IC tda 2003 in the library. As a Mechanical Engineer, I don't know much about this softwares, but I need to simulate this circuit. Is there any way to download a library wich has this component? Or I have to do this simulation in another software? Thanks all of you and I'm sorry if there was some grammar mistakes.
