drjohsmith
- Joined Dec 13, 2021
- 1,679
to answer the original question,Thank you, Mr. Strantor. Your concerns are warranted and very real.
To avoid that issue, the typical DC-injection braking circuit has a power resistor of some 50 to 100 ohms in series with the braking capacitor(s) to limit the initial peak current through the motor windings during capacitor discharge to something less than the normal current draw of the motor. The object is to stop the motor over a time period that would be, say, three to four times as long as it takes to bring the saw up to speed.
the overhead on capacitors voltage rating is zero.
outside the spec, anything could happen,
you might have a good one, and it works fine at say 25% over voltage,
you could have a bad one, that pops just a bit over voltage
and it will probably get worse over time,
