How much resistor wattage to use?
livelongpranav
Joined Oct 18, 2017
19
In a circuit, how much wattage resistor should I use? I'm using a 400 mAh 9V battery so should I use a resistor of wattage more than 9x0.4=3.6 watts!!! Coz I always used the 1/4 watt one that came with my kit. Does a circuit use up all the current and voltage or should my v and i values be lesser in the VxI=P equation?
philba
Joined Aug 17, 2017
959
400 mAh is the capacity of a 9V battery. A 22.5 ohm resistor across the terminals would draw 400 mA (and in theory last an hour). You'd want that resistor to be 5W (standard size with some headroom) as that wouldbe the only thing consuming current. Note, the 22.5 ohm resistor would not actually draw 400 mA because batteries have internal resistance that needs to be factored in. There are techniques for measuring IR, if you care.
