How much memory program occupy
mukesh1
Joined Mar 22, 2020
68
When you write program for any microcontroller. How do you find how much memory, program occupy.
I work with XC8. I have no idea. Does complier tell size of your program?
Papabravo
Joined Feb 24, 2006
22,111
Most compilers will provide a listing that shows the memory used by the program. If the compiler allows you to combine "relocatable modules" into a single executable, this is often called a "linkage editor" map. This information should be produced by default, but in some cases you may have to look for a configuration option to turn it on.
Looking at the hex files is a good idea, but doesn't tell you much about the individual nodules. It can also trick you if the code does not reside in a single contiguous block. The linkage editor map is the way to go if you're looking for details.
