Yes, it was in dot mode. The vector mode gives a lot of excursion spikes. ERES mode does give a better display but apparently since it is a meas function, it cannot have meas applied to it. Have to measure it the old way by the graticule. K, learned a couple of things. Tried averaging the signal with 128 points but it was not as good as the ERES trace. This is a 10mV signal @ 1kHz.The dots display suggests otherwise.
2 further thingsYes, it was in dot mode. The vector mode gives a lot of excursion spikes. ERES mode does give a better display but apparently since it is a meas function, it cannot have meas applied to it. Have to measure it the old way by the graticule. K, learned a couple of things. Tried averaging the signal with 128 points but it was not as good as the ERES trace. This is a 10mV signal @ 1kHz.
Because that was the point where the waveform stabilized. I also thought it was odd. I could stop the waveform display to fix the trace in place on screen but would rather not.Why are you examining a waveform with the trigger level set to outside its amplitude ?
Hmmm... I only saw the availability for 2 "Functions". K, I will investigate further averaging the ERES trace. What the screenshot does not show is there is a secondary slower frequency of the ERES trace (in addition to the 60Hz noise). Oscillation possibly?You have engaged 1 Maths operation but in these scopes you can use 4 which permits Maths on Maths where you can use some further averaging on the ERES trace.
Yes, I use that function often but the math ERES Function traces cannot be hidden and must be turned OFF. I wish they also had the Hide ability.Hiding traces is in the menu for each channel
No offset, just didn't need to change it...I see you have Ch1 AC coupled,
I'm good for now but thanks for the offer.I can slip the beta your way if required
https://www.daycounter.com/Calculators/Thermal-Noise-Calculator.phtmlYes, the TinySA does look to be limited. Getting up the $1k price range things looks much better. The Siglent Technologies SSA3021X ($1400) has some decent specs and the 1 Hz to 1 MHz RBW (Resolution Bandwidth) is impressive. I want one. I always had access to the best Spectrum Analyzers at several jobs and am spoiled.@dovo I have been "shopping" for a signal analyzer and looked at USB and TinySA along with used HP variants. USB's are out due to several reports of poor performance and still looking at whether TinySA vs. HP (or similar bench analyzers) are the way to go. The problem with USBs seems mostly related to the PC software and not necessarily the hardware (for some units) but there is also a question as to accuracy of signal with their low bit resolution and minimum bandwidth. A used bench analyzer under 1k USD is which way I'm leaning and keeping a watch on eBay's availability but have a few other pricey items also on the wish list that have priority. Stopgap, a TinySA (or similar) is a possibility that I'm still investigating or saving the money to go to a bench unit. One of these days... Thanks for your input.
