How know the capacitor number
28,457
YES, the identifier text on the PCB is VA1, and since the fuse has also failed, the varistor did perform some protection and short circuited the high voltage.
So now the varistor must be removed, and a replacement installed to continue the protection. In addition the fuse must be replaced with another fast fuse of the same voltage and current rating.
The replacement varistor must be rated for protecting whatever voltage line is specified for the inverter.
