How is the auxiliary voltage created here? How does voltage behaviors in this simple circuit?
fordsi
Joined May 25, 2021
I'm learning on my own and got a German book. In the chapter about diodes, the author shows how auxiliary voltage is created with the help of diodes (see attached image). He doesn't really explains what is going on a beginner level and I am not sure if I should go one with reading or try to understand before I move one, that is why I am here. I already learned about the Kirchoff's law.
We have 9 V battery, on the left side 33k R, two diodes and on the right side three diodes.
1) Are the 9 V divided between left and right part of the circuit? E.g. 60% of voltage available on the left and 40% on the right side of the circuit?
2) I can't tell the voltage drop on 33k R, because I don't know how much voltage is used on the right side of the circuits (three diodes), right?
3) Why is the need/auxiliary voltage is between resistor and the two diodes? It feels like the needed voltage of 1.2V should be available after all three components.
Thank you for your time.
The paragraph about the circuit:
An additional lower voltage is often required in an electronic circuit. In our example, an "auxiliary voltage" of approx. 1.2 to 1.5 V can be generated at the two diodes (D1 and D2).
This corresponds to the voltage loss that occurs "automatically" at the two diodes. The resistor R can have a rather high ohmic value, if the current drop is only small. The drawn capacitor C serves for "smoothing" the 1.2 V voltage. At the Diodes D3, D4 and D5 there is a voltage loss of about 3 x 0.6 V (= 1.8 V). The residual voltage is thus approx. 7.2 V. Here no series resistor is necessary and the max. current consumption can be as high as the silicon diodes and the batteries can handle.
ericgibbs
Joined Jan 29, 2010
21,622
hi ford,
Welcome to AAC.
If the actual forward drop of a diode is unknown, a value of 0.7V is assumed, does this help you.?
E
I see in the example image, a forward diode voltage of 0.6V is assumed.
fordsi
Joined May 25, 2021
Hello Eric, thanks, AAC looks like a great place to start my "electrical adventure".
Unfortunately your reply doesn't help at all, the paragraph already tells that the voltage drop on a diode is 0.6V.
Could you explain me how the voltage behavior in this circuit?
ericgibbs
Joined Jan 29, 2010
21,622
hi ford,
Downloaded your image, I will post a marked up version.
E
Update:
Does this help, note to get the 7.2V on the right side of 3 diodes, there must be a load.
As the voltage across each diode is still 0.6V it means the current must the same in both diode paths, hence the 30k5 load.
E
Typical Diode image.
