Good Day,
Would you mind having a look at my code and give me a rating of what you think of it? What the code does is it Takes a hexadecimal(0xAF) byte and then detects the Ascii characters used in this byte and outputs them separately.
The program works quite well from what I tested.
(I tried getting the comments in a nice column in the post, but I couldn't get it right)
Code:
;*************HexToAscii********************************************************
;Name:
;Student Number :
;Program Description :The program detects what Ascii characters would
; represent the Hexadecimal Values in Hexbyte and stores
; them in two seperate registers. AsciiTens for the MSB and
; AsciiUnits for the LSB.
;Registers Affected : w,FSR,INDF,STATUS,20h,21h,22h,23h
;Input registers : 20h
;Output registers : 21h,22h
;Process details : Seperate the 4 MSB and the 4 LSB and then detect the Ascii
; character represented by these bits.
;**********Config**************************************************************
;PIC16F877A
;*************Equates***********************************************************
FSR equ 04h
PCL equ 02h
INDF equ 00h
Status equ 03h
Carry equ 0
RamBank0 equ 20H
;*************Variables*********************************************************
cblock RamBank0
HexByte ;Reg for HexByte,Input 20h
CharTens ;Reg for CharTens,Output 21h
CharUnits ;Reg for CharUnits,Output 22h
Counter ;Reg for Loop Counter 23h
endc
RES_VECT CODE 0x0000 ; processor reset vector
GOTO START ; go to beginning of program
; TODO ADD INTERRUPTS HERE IF USED
MAIN_PROG CODE ; let linker place main program
START
;*************Initialization****************************************************
;Prepares and clears the nessesary registers for inputs,outputs and Loops
;Effected Registers
;CharTens 21h
;CharUnits 22h
;w reg
;Counter 23h
;FSR
clrf CharTens ;Clears Output 21h
clrf CharUnits ;Clears Output 22h
movlw B'00000100' ;Moves decimal 4 to w reg to put into Counter
movwf Counter ;Moves w reg to Counter 23h
movf HexByte,0 ;Moves HexByte to w reg
movwf CharTens ;Moves w reg to CharTens 21h
movwf CharUnits ;Moves w reg to CharUnits 22h
movlw 21h ;Moves Hexadecimal value 21h to w reg
movwf FSR ;Prepares the FSR to point at reg 21h which is
;CharTens and the first output register
;*************DetectAscii*******************************************************
;This is the main code. It will call the functions needed to rotate and detect
;the Ascii present in the HexByte and store them in the correct registers
;It first handels CharTens after which it increases the FSR to point to
;CharUnits.
;Effected Registers
;CharTens 21h
;CharUnits 22h
;w reg
;Counter 23h
;FSR
DetectAscii
CALL ShiftRight ;Calls ShiftRight function to manipulate
;CharTens
movf INDF,0 ;Moves the manipulated CharTens to w reg
CALL AsciiChar ;Calls AsciiChar to detect what Ascii character
;represents CharTens Value
movwf INDF ;w reg (which contains the value returned from
;AsciiChar) to the output reg of CharTens 21h
incf FSR ;Increses FSR to point to CharUnits 22h
CALL ShiftLeft ;Calls ShiftLeft function to manipulate
;Manipulate CharUnits
CALL ShiftRight ;Calls ShiftRight funtion to manipulate
;CharUnits
movf INDF,0 ;Moves the manipulated CharUnits to w reg
CALL AsciiChar ;Calls AsciiChar function to detect what Ascii
;characrer represents CharUnits Value
;AsciiChar) to the output reg of CharUnits 22h
GOTO $ ;loop forever/Program End
;*************ShiftRight********************************************************
;This funtion clears the fisrt bit of the register indicated by the INDF and
;then shifts this register to the right. This loop loops 4 times before it
;resets the counter and returns to the main code.
;This function is used to move the 4 MSB bits in the byte to the first 3 LSB
;bits (eg 10101111 -> 00001010)
;Effected Registers
;CharTens 21h
;CharUnits 22h
;w reg
;Counter 23h
ShiftRight
bcf INDF,0 ;clears the fisrt bit of the reg indicated by the
;INDF
rrf INDF ;Rotates the reg indicated by the INDF to the right
decfsz Counter ;decreases counter and skips next instruction if the
;counter is zero
GOTO ShiftRight ;loop ShiftRight
movlw B'00000100' ;Resets the counter
movwf Counter
return ;Returns to main code DetectAscii
;*************ShiftLeft*********************************************************
;This function rotates the register left. This loop loops 4 times before
;resting the counter and returning to the main code
;This function is to prepares the INDF(CharUnits 22h) for the ShiftRight
;function that will sepereate the needed bits
;Effected Registers
;CharTens 21h
;CharUnits 22h
;w reg
;Counter 23h
ShiftLeft
rlf INDF ;Rotates the reg indicated by the INDF to the left
decfsz Counter ;Decreases counter
GOTO ShiftLeft ;loop ShiftLeft
movwf Counter
Return ;Returns to main code DetectAscii
;*************ReferenceTabl*****************************************************
;This is the reference table that will detect the Ascii Character representing
;the hexadecimal vaule. It adds the w reg(which will be loaded with the
;manipulated CharTens and CharUnit values) to the PCL to indicate which one the
;function should return.
;Effected Registers
;w reg
AsciiChar
addwf PCL,1
retlw B'00110000' ;Decode 0
retlw B'00110001' ;Decode 1
retlw B'00110010' ;Decode 2
retlw B'00110011' ;Decode 3
retlw B'00110100' ;Decode 4
retlw B'00110101' ;Decode 5
retlw B'00110110' ;Decode 6
retlw B'00110111' ;Decode 7
retlw B'00111000' ;Decode 8
retlw B'00111001' ;Decode 9
retlw B'01000001' ;Decode A
retlw B'01000010' ;Decode B
retlw B'01000011' ;Decode C
retlw B'01000100' ;Decode D
retlw B'01000101' ;Decode E
retlw B'01000110' ;Decode F
GOTO $ ; loop forever
END
