How electrically common points have same voltage
ivepoli
Joined Apr 19, 2016
4
I read about voltage in capacitor and see that voltage is dependent on distance from the two plates, like gravitational potential energy depends on height.
But how do electrically common points in circuit have the same voltage? Isn't voltage dependent on location in wire?
18,104
Right, if there is a conductive path between two points, meaning they're common, any voltage imbalance causes current to flow and the imbalance quickly disappears. Like water seeking a level, only much much faster.
hp1729
Joined Nov 23, 2015
2,304
Very low resistance along the wire thus very little difference in voltage. There is a difference but your meter could not measure it.
12,135
Yes, but the difference usually is microvolts, too small to measure and way too small to care about.
Technically, most of the time two points in a circuit are connected there is electron flow (current) from one point to the other. But copper is an excellent conductor, and the resistance in the copper connection is so small relative to the energy being moved that the voltage difference is hard to measure. Microvolt meters and micro-ohmeters are designed specifically for these kinds of measurements.
