How does this comparator circuit work?
Blue_Electronx
Joined Jun 10, 2019
112
I'm trying to understand the circuit below. I know the comparator voltage reference is 13/2 = 6.5V and is set at the inverting input of the comparator. However, my confusion is about the input voltage in the non-inverting pin. Is it affected by capacitor C1? When the FET is turned on, R1 and R2 form a resistor divider, but how is it affected by C1?
NOTE: FET M1 is not actually a FET. It's an inverter like this one.
ericgibbs
Joined Jan 29, 2010
21,541
hi,
At rest, C1 is not charged, voltage across it is zero.
When pulsed, the lower end of C1 is pulled down to 13v * (1.2/(2.5+1.2) = ~ 4.2V
C1 will charge exponentially charge to approx 13V-4.2V = 8.7v, it could be just a noise filter or need to create a slow edge for the comp.
E
EDIT:
LTS plot of the C1 voltage, corrected.
28,076
The ultimate effect of the C1 capacitor will be for the comparator to oscillate as the positive input voltage slowly passes the inverting input voltage. Also, unless that comparator is powered, nothing at all will happen. One more thing is that I would consider a 4007 CD4007? to be an inverter. The data sheet calls it an analog switch, and so would I.
38,703
I see no reason for Q1, as the comparator can just drive the SCR directly if the comparator inputs are reversed to keep the signal polarity at the SCR input the same.
ebeowulf17
Joined Aug 12, 2014
3,307
Is that still true if the comparator has an open collector output, as many do? Wouldn't it be unable to source current like Q1 does in that case?
28,076
Because this comparator also shows no power connections we can presume that it is a theoretical comparator or a simulation comparator and so does not need a power connection. There are many different kinds, the LM339 has no pullup, only open collector NPN output, while the LM311 has both collector and emitter available. But because no type was specified it does not matter..
Blue_Electronx
Joined Jun 10, 2019
112
The comparator used is the LMC6772. It's a low power comparator. Perhaps that's why a PNP transistor is used? Do you think that just leaving R6 and R7 would work?
ericgibbs
Joined Jan 29, 2010
21,541
hi Blue,
For the cost a PNP general purpose transistor I would use the original circuit.
The LMC is open Drain output and say the SCR requires 10mA of trigger current, means that the value of R6 would have to be reduced.... etc
Do you have details of the SCR .?
E
ericgibbs
Joined Jan 29, 2010
21,541
hi,
That could be Gated On using a resistor pull up resistor to +Vdd.
If you omit the PNP, as already pointed out you must change the comp inputs over in order to keep the correct gate sense.
E
38,703
The S6S2 requires a minimum of 50μA to trigger
The LMC6772 output is rated for a 5mA (sink) load, so will have no problem driving the SCR.
But you would need to leave R5 and R7 (omitting R6 and the transistor) as well as reversing the inputs to the comparator.
Blue_Electronx
Joined Jun 10, 2019
112
In the circuit attached below, what if the cathode of the SCR is referenced to - 13V, while the comparator is referenced to common or 0V, that is, single supply? Would the PNP still be needed? The circuit has dual power supply 13V, 0V, -13V.
Alec_t
Joined Sep 17, 2013
15,149
If the PNP were not there, then because the comparator output only swings between 0V and +13V it could never be below the turn-on voltage of the SCR.
