How does it actually work? (noob multimeter question)
jbuddyman
Joined Jun 27, 2016
7
Hi, I am a young hobbyist, and am new to the all about circuits community.
So I was tearing apart some multi meters and I thought to myself " Since multi-meters can measure AC, then why is there no transformer inside?" I know that transformers are meant to step up OR down AC voltage. Say for an example, I measure mains 120V AC. How is this meter reading that, but when I tear it apart, there is no transformer? Maybe there is, but I just am not seeing it. I am hoping someone can help me figure this out, or even educate me a little bit.
To all that reply, thanks for being patient with me, and helping me out. I don't know a whole lot! :)
#12
Transformers can work with AC, but so can resistors, capacitors, and inductors. There is no law that says only one kind of device can work with an AC voltage.
If you just connect your AC voltage to the right couple of resistors, the voltage will be reduced to the range that an ADC can work with. Resistors are good because they don't change their behavior with frequency changes. Capacitors and inductors do. You can still make a voltage divider with capacitors or inductors, but you immediately have to be aware of what will happen in different frequency ranges. A resistor will sit there like a lump, doing nothing but resisting, clear into the gigahertz range, but capacitors and inductors can get really bad at a few MHz. Self resonance, diminished capacitance, that sort of thing.
KL7AJ
Joined Nov 4, 2008
2,229
Depending on the sophistication of the instrument, AC can be either rectified first and then digitized.....or digitized directly from the AC with a high speed sampler, and then numerically calculated. There are advantages to both methods.
ian field
Joined Oct 27, 2012
6,536
Some older multimeters did have a transformer - but I think it was for current measurement and only on some of the ranges.
Analogue meters have a fairly simple rectifier arrangement so its just another DC measurement as far as the movement is concerned. They usually used a germanium diode for its low Vf.
DMMs have a precision rectifier - on very old ones it was an op-amp and a couple of diodes. Nowadays its all integrated into a dedicated chip along with the ADC and display drive logic.
jbuddyman
Joined Jun 27, 2016
7
Thanks for letting me know that. You and AACFanatic I think nailed it, and made me understand this mystery. I don't use analog meters, even though my dad had one and he let me use it a long time ago. Now all my meters are digital. I knew there were some rectification, and precision resistors involved, but I didn't know what did the stepping down. I was just wondering how the meter can read 120V since that's a pretty high voltage. Thanks everyone, and I welcome everyone's perspective on it. All multimeters are different however, so we should always keep that in mind.
ian field
Joined Oct 27, 2012
6,536
Some meters go up to 1000V or even 2500V - Google "multiplier resistance".
The method used in a cheap DVM is generally based on full wave precision rectification and an averager. The averaging circuit has some frequency dependence. The average value is multiplied by a "fudge factor" to make the value of an mathematically averaged sine wave equal to the RMS value of the voltage.
Here are some offerings of Analog Devices on their TRMS converter chips: http://www.analog.com/en/products/linear-products/rms-to-dc-converters.html
This http://www.linear.com/product/LT1088 technology isn't used anymore, but was good to 100 MHz.
One important parameter in some circuits is the crest factor. See: https://en.wikipedia.org/wiki/Crest_factor
It's too bad that the side doesn't show the "precision rectified average which starts with the flipped negative axis. The true average value of a sine wave is zero. The average value of the abs (sin(x)) is not.
TRMS (True RMS) maters usually allow you to read just the AC component and the DC+AC component.
The RMS value of a voltage will be the equivalent DC value needed to satisfy ohms law with a resistor. e.g the same power dissipation is a resistor.
Oscilloscopes offer AC and DC coupling which probably should be read as AC and AC+DC, but DC means "Direct coupled" in this context.
RMS means root mean squared and literally, that's what it is. The average of the sqrt of the waveform squared.
EDIT: Added and corrected stuff since the like by the TS.
32,989
That's not an AC issue. After all, the meter can read 120 V (and higher) DC voltages and that doesn't see surprising to you (since you didn't ask about it). Some multimeters (particularly older multimeters) simple convert AC to DC and then use the same circuitry that was used to measure DC voltages, but with an appropriate scaling factor. On an analog meter, the scaling was done by simply printing a difference scale on the meter face.
ian field
Joined Oct 27, 2012
6,536
And, of course, you can add a high voltage probe (voltage divider) to measure voltages in the tens of kV range.
It was probably EPE that published a project about a year or so ago.
Designed for 25kV CRT TV EHT. Housed in a length of plastic waste pipe was a long narrow PCB with carefully arranged resistors.
