What does this iC actually do?
Canobi
Joined Mar 4, 2015
29
Hey guys
I'm in a bit of a quandry regarding a device and could use a little help in clearing things up. I've been shopping around on the RS website for a 5v 2A fixed regulator, ideally something that comes in a smaller package size than DPAK. Unfortunately, SOT-223 variants are quite pricey and as this is a personal project, so I'd like to keep costs down where I can, thus I have expanded my search criteria to other package types.
On the website, in the LDO regulator category is the AP2280, which comes in a DFN2016-6 package. The device is listed as a 5v 2A fixed regulator, however, there seems to be more than one confliction between the site info and the device's datasheet, which states that it's a single channel slew rate controlled load switch, not a 5v 2A fixed LDO regulator. I am still learning and not familiar with many devices yet, so I don't know if this will do the same as a regulator and that is why it was put in the category it was on the website, or weather it's RS who are in error.
Here are some screen grabs show the conflictions:
RPLaJeunesse
Joined Jul 29, 2018
264
And note the absolute maximum input voltage is 6.5V - so the supply feeding this chip better be limited to no more than that under any and all conditions.
dl324
Joined Mar 30, 2015
18,457
Always trust the manufacturer more than a distributor.
Papabravo
Joined Feb 24, 2006
22,111
To answer the original question, a load switch is used in a system to manage power consumption by turning a device off and on, usually according to some schedule.
