How does DPCM work in digital systems?
FabulouSS
Joined Feb 5, 2019
10
Hello!
I can not figure out the implementation of DPCM in a digital system. I have an 8-bit ADC, the output of which is a digital signal (discretized and quantized) - this is PCM. I don’t know how to make DPCM from PCM.
My questions are as shown below:
1. In the diagram below, there is a quantizer - why is it needed if the signal is already quantized before it?
2. Also, I do not quite understand what a predictor is. In some sources, this is a simple one-measure delay line (sample).
3. What method can be used in the entropy encoder for compression?
Thanks for attention! :)
I use google translator.
KeithWalker
Joined Jul 10, 2017
3,610
Hello!
It's all here:
https://en.wikipedia.org/wiki/Differential_pulse-code_modulation
FabulouSS
Joined Feb 5, 2019
10
If you can show us what you think the answer is, we can maybe help you.
I will try to communicate in order to be understood!
I have assembled such a circuit according to the model (see Pic. #1).
So that at the output of the DPC modulator there would be at least 1 bit less (taking into account the sign bit) than with ordinary PCM, I had to increase the sampling frequency by 10 times! Explanations on the chart (see Pic. #2).
In this scheme, I did not add an entropy encoder, because I don’t know what formula should be encoded. Where could I be wrong? Although it seems to me that everywhere. :(
