How do you determine the Counter electromotive force (CEMF)?
Jiwoo
Joined Feb 6, 2023
19
there is this circuit given and I should generally calculate the Counter electromotive force. Any Ideas how it is done?
Jiwoo
Joined Feb 6, 2023
19
@ericgibbs Hi, thanks :)
Well the thing is, there are multiple terms that I came across which where I don't know what the difference is. From my understanding, the CEMF voltage is the voltage on the Ze resistors. So I would multiply the current of 9R and R with the Ze resistors. But I am not sure if I am on the right direction.
WBahn
Joined Mar 31, 2012
33,171
What does the triangle represent?
Counter-EMF is generally the EMF produced by an inductor in response to a change in current. I don't see how that applies here (unless the Z elements have an inductive component). What is Ysub(something unreadable)?
Jiwoo
Joined Feb 6, 2023
19
@WBahn The triangle is a Differential amplifiers. The task says that the system is getting disturbed by capacitive coupling. By Ysub I think you mean the voltage on the left, thats the measurement voltage.
