Lundwall_Paul
- Joined Oct 18, 2011
- 236
Use epoxy under the socket to secure tight to the pcb and this will reduce solder joint breaks.I realize that it needs to be soldered to the PCB, but after opening can closing the socket about 30 or more times, the lever on the arm slides the contact where the solder meets the leads and cracks the solder joint. I need to mount or drill a whole into the zif socket so it doesn’t wiggle within the PCB holes. I thought this could use these zif sockets as a test socket, but maybe there is something different out there in the market ?
