Because they weren't blindingly obvious at the time. Today, we recognize KCL as simply a manifestation of the conservation of charge, but at the time, the theory of electricity was far less settled. Kirchhoff published his laws in 1845 (while a 21 year old student), based on empirical analysis of circuit behavior, as a way of extending Ohm's Law (which was met with great skepticism when it was published less than twenty years earlier) to networks of components. You might ask why it wasn't obvious by just deriving them from Maxwell's equations? Simple. Maxwell's equations weren't published for another twenty years after Kirchhoff's laws. Like Ohm, it took about a decade before the validity of Kirchhoff's Laws were widely accepted.I’ve always been bemused as to why Gustav Kirchhoff was credited with coming up with two “laws” which merely state the blindingly obvious. And then people invent unrealistic circuits for students to solve using his laws.
It’s just a bit of algebra. As already suggested, assume the voltages at the top and bottom of R4 are Va and Vb respectively and write down the current in each resistor according to Georg Ohm’s law. I recall that Gustav mentioned something about the sum of currents into a node are zero, but how could anyone before him think otherwise?
As I stated, to get further assistance, you need to show your best attempt to work YOUR homework problem. We are not here to do you work for you. So show your work as far as you can take it. Don't worry about whether it is wrong or not. By seeing what you have done wrong, or what you have overlooked, we can help steer you onto the right path.I'm not sure either, Jerry-Hat-Trick. I haven't figured out how to solve this problem yet, and no one has taken the time to provide a detailed, step-by-step explanation that I could learn from.
Wow, you're really talented. Your solution is both brilliant and simple. Thank you—you are truly a thoughtful person.Your solution is almost good.
I =10V/( (Rb+R5) || (Rc+R6) ) = 10V/(R1 + Ra + ((Rb + R5)*(Rc + R6))/((Rb + R5) + (Rc + R6))) = 2.02726A
I_RbR5 = I * (Rc + R6)/((Rb + R5) + (Rc + R6)) = 1.12436A
I_RcR6 = I - I_RbR5 = 2.02726A - 1.12436A = 0.9029A
Therefore:
V_R5 = I_RbR5 * R5 = 1.12436A * 5Ω = 5.6218V
V_R6 = I_RcR6 *R6 = 0.9029A * 6Ω = 5.4174V
But you cannot use I_RbR5 and I_RcR6 to calculate I_R2 or I_R3 due to the delta-to-Y transformation.
You can do it only for the components that are "outside" the delta-to-Y transformation. Do you get it?
I meant R1, R5, and R6 only.
But since we already know V_R1, V_R5, and V_R6, we can use this to find for :
V_R2, V_R3, and V_R4
V_R4 = V_R5 - V_R6 = 5.6218V - 5.4174V = 0.2044V
V_R2 = 10V - V_R1 - VR5 = 10V - 2.02726V - 5.6218V = 2.3509V
V_R3 = 10V - V_R1 - V_R6 = 10V - 2.02726V - 5.4174V = 2.5553V
But this is not the solution you wanted.
Why did you use Kirchhoff's laws to solve for the whole circuit at once?
A quick tip:
First, we label all voltages with plus and minus depending on the assumed current direction (chosen arbitrarily) and label all current directions with an arrow.
Next, identify and label all KVL loops in a circuit (two loops).
Now, when going around the loop and encountering a voltage rise (from – to +), you assign it a "+".
But when you encounter a voltage drop (from + to -) in a loop, you assign it a "-".
Or in simple words:
We add all the voltages whose arrows align with the loop direction, and subtract all those directed opposite to the loop direction.
At the end, we sum all positive and negative terms and set it equal to zero.
loop 1:
V1 − I1*R1+ I2*R2 = 0
loop 2:
− I2*R2 − I3*R3 = 0
And we're done.
Of course, the rules about which voltage we treat as positive and which as negative are arbitrary.
But if we decide to use one of them, we have to stick to it religiously.
random problem with guitar tuner project | Microcontrollers | 2 | |
! endless barking dogs, problem | Off-Topic | 10 | |
| E | one sensor with multiple protocol [SOLVED] | Microcontrollers | 34 | |
can some one explain how do you solve task 4 | Homework Help | 2 | |
| D | Pi 5 Hats needed (solved) | Microcontrollers | 0 |
