How do I run this project?
Ya’akov
Joined Jan 27, 2019
10,355
The GitHub page has all the information and it is very well documented.
Prerequisites
  • Python 3.7.4 (code has been tested with this version)
  • ffmpeg: sudo apt-get install ffmpeg
  • Install necessary packages using pip install -r requirements.txt
  • Face detection pre-trained model should be downloaded to face_detection/detection/sfd/s3fd.pth. Alternative link if the above does not work.
Below that is information about the datasets and other things. What are you not finding documented?
